199 Enduro Posted March 27, 2021 Report Share Posted March 27, 2021 While turning the countershaft on my 199 by hand it stops turning once every revolution. If I turn it harder it will rotate. The transmission works as it should although the shifting is a bit notchy. What is the cause the sticky countershaft? Quote Link to comment Share on other sites More sharing options...
199 Enduro Posted March 27, 2021 Author Report Share Posted March 27, 2021 Turning the countershaft in neutral Quote Link to comment Share on other sites More sharing options...
bullylover Posted March 28, 2021 Report Share Posted March 28, 2021 Try changing the gearbox oil, that may do the trick. It shouldn`t do that. Quote Link to comment Share on other sites More sharing options...
199 Enduro Posted March 28, 2021 Author Report Share Posted March 28, 2021 I have fresh gear oil in trans. The 199 sat for 24 years while I was working heavy hours. I did ride it last year a few miles. I wonder if changing the fluid every two rides will fix the problem. I would not want to damage the transmission by riding the bike. Quote Link to comment Share on other sites More sharing options...
motovita Posted March 29, 2021 Report Share Posted March 29, 2021 4 hours ago, 199 Enduro said: I have fresh gear oil in trans. The 199 sat for 24 years while I was working heavy hours. I did ride it last year a few miles. I wonder if changing the fluid every two rides will fix the problem. I would not want to damage the transmission by riding the bike. Does it behave the same in both directions? If you rotate it until it binds does it rotate freely the other direction then bind up again in the same spot every time? If you loosen the sprocket nut does it change? Is the shoulder on the sprocket on the inside? How did you come to notice this? Quote Link to comment Share on other sites More sharing options...
199 Enduro Posted March 30, 2021 Author Report Share Posted March 30, 2021 Yes, It rotates freely in both directions and binds in the same spot. I noticed this when I would roll the bike in neutral there would be momentary tension and then release on the chain. I will pull the sprocket tomorrow and let you know about the sprocket nut and shoulder. Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted March 30, 2021 Report Share Posted March 30, 2021 Are you turning it with the chain attached to the rear wheel, if so check that its not the rear brake Quote Link to comment Share on other sites More sharing options...
199 Enduro Posted March 30, 2021 Author Report Share Posted March 30, 2021 No, I have removed the chain. 1 Quote Link to comment Share on other sites More sharing options...
199 Enduro Posted March 31, 2021 Author Report Share Posted March 31, 2021 Getting 32 mm socket this weekend. Quote Link to comment Share on other sites More sharing options...
motovita Posted March 31, 2021 Report Share Posted March 31, 2021 1 hour ago, 199 Enduro said: Getting 32 mm socket this weekend. 1 1/4" will probably work too. Quote Link to comment Share on other sites More sharing options...
199 Enduro Posted April 5, 2021 Author Report Share Posted April 5, 2021 I removed the sprocket and the problem still exists. There are shoulders on both sides of the sprocket. To take off the sprocket I bent the washer straight and tapped the nut and the socket with the flat end of a small ball peen hammer. To my surprise when I put the socket and breaker bar on the nut it turned free with no effort. The chain wasn't even on. I was attempting to rock the sprocket back and forth at the bind hoping to loosen what ever is causing this problem. I am going to tighten the nut so I can rock the sprocket at the bind. Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 6, 2021 Report Share Posted April 6, 2021 (edited) I'd try it without the sprocket to eliminate it. Any "telltale" marks on the sprocket or case ? Edited April 6, 2021 by b40rt Quote Link to comment Share on other sites More sharing options...
199 Enduro Posted April 6, 2021 Author Report Share Posted April 6, 2021 The sprocket and case look normal. Sprocket teeth have normal wear. Quote Link to comment Share on other sites More sharing options...
