TLR steering bearings
keychange
This is complicated, assuming you mean taper rolling bearings, if not then I cannot help.
The upper bearing is 48.5 x 26 x 15, the lower is 48.5 x 27 x 17. or some lower bearings are 15 deep with a reduced diameter boss on the lower side, note the internal diameters are different upper to lower.
