mcman56 Posted April 2, 2021 Report Share Posted April 2, 2021 Is there a way to soften an Evo shock, 2016 4t? (I have the adjustment at full soft.) The manual lists an oil so a thinner oil may do the trick. But, I don't see a pressure valve. Can the oil be changed? I just put thinner oil in the forks at a 5 mm lower level and like the feel. At 152 pounds and a non aggressive riding style, I suspect softer is better. Quote Link to comment Share on other sites More sharing options...
carlos Posted April 3, 2021 Report Share Posted April 3, 2021 23 hours ago, mcman56 said: Is there a way to soften an Evo shock, 2016 4t? (I have the adjustment at full soft.) The manual lists an oil so a thinner oil may do the trick. But, I don't see a pressure valve. Can the oil be changed? I just put thinner oil in the forks at a 5 mm lower level and like the feel. At 152 pounds and a non aggressive riding style, I suspect softer is better. I see your from California, contact Randy Lewis at R-racing 661-821-9952. He knows every thing about rebuilding Beta shocks, i have an Ohlins on the rear of my 2016 Factory 4T that he modified, it's still my favorite bike. Quote Link to comment Share on other sites More sharing options...
