Pro Rear Wheel In Scorpa
speckled hen
Hey Hen
Not sure about the Pro wheel, but a Sherco is 2mm thinner. To use one of them you need to space out the disc with washers (ground off to fit) and make up a 2mm spacer between the bearing. Same thing goes if you space the sprocket side, but the disc is less work! If'n you don't and think 2mm is not worth worrying about you will F up and bend things that should not be bended :D
Downunder
