GrahamM78 Posted April 12, 2021 Report Share Posted April 12, 2021 I've got a 2017 GasGas Contact, and I need to check out the top end after a cold seizure (different story / post 😔). I've found a service manual with information on disassembling the motor, but it doesn't include steps to remove the motor from the frame. I'm relatively comfortable working on bikes, but I though I would check if anyone has some tips / gotchas or even a manual as that may save me some headaches :) Are there any parts that need to be replaced when removing the motor from the frame? Thank you! Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 13, 2021 Report Share Posted April 13, 2021 If you are just doing the top end, leave it in the frame. You can pull the motor without removing the skid plate. Which will keep the frame in place. Quote Link to comment Share on other sites More sharing options...
arnoux Posted April 13, 2021 Report Share Posted April 13, 2021 As above, just pull the Airbox, and fuel tank, then remove the radiator to give you a bit more room, and then the top end can be removed quite easily. 1 Quote Link to comment Share on other sites More sharing options...
GrahamM78 Posted April 13, 2021 Author Report Share Posted April 13, 2021 Thanks @arnoux and @lineaway - that's very helpful! I'll give it a go. Quote Link to comment Share on other sites More sharing options...
d2w Posted April 13, 2021 Report Share Posted April 13, 2021 While the radiator/fan is out, drill-out the rivets which secure the fan to the rad and replace with short sheet-metal screws. Then in the future you can remove the fan (say to replace the fan motor ) or to ease access to the top-end without having to remove the radiator itself. 1 Quote Link to comment Share on other sites More sharing options...
GrahamM78 Posted April 17, 2021 Author Report Share Posted April 17, 2021 I got ahold of Jim Snell with Rising Sun and I'm going to do a cylinder swap. I've gotten as far as unbolting the cylinder - some of the bolts are pretty hard to get to - especially the back right under the exhaust. can't get a socket on it - well I can get the socket but not an extension / driver and a spanner doesn't have room to turn - and also seems a little loose fit so I don't want to strip I did use some heat on the others and that helped. What tools do you use to remove the cylinder? I think I will have a little more room if I remove the exhaust, so I'll try that once getting on a center stand to remove the rear shock bolt Quote Link to comment Share on other sites More sharing options...
richt Posted April 17, 2021 Report Share Posted April 17, 2021 When you say a spanner has no room to turn are you using open jaw spanners? If so then I think you need to use ring spanners. or Combination spanners which are ring at one end and open jaw at the other. Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 18, 2021 Report Share Posted April 18, 2021 Well you have to remove the header pipe, and removing the tank and muffler is no big deal. Quote Link to comment Share on other sites More sharing options...
GrahamM78 Posted April 18, 2021 Author Report Share Posted April 18, 2021 Reveal hidden contents I was able to get it - I was using a ring spanner. the front left (clutch side) was a real #$!%@. the gap is so small between the nut and cylinder on the 2017 contact (maybe 1/8") that I had to grind down a ring spanner to get around it. Thanks all, cylinder removed and off for a swap! Quote Link to comment Share on other sites More sharing options...
