flywheel removal
hedgelayer
would recommend you get the correct puller as a slide hammer could buckle flywheel, and sometimes even with the correct puller they can be stubborn to get off. If it is, whack up the tension and leave it overnight,usually works.
And there's a trick to using the puller tool correctly. After you've ensured that all threads are clean, thread the outer piece into the flywheel. Once you've bottomed-out, thread the inner piece into the outer. Snug the inner piece to the crank. Tighten but only until solid. Then hit the flywheel with a (hopefully soft, maybe copper (?)) mallet. Then tighten the inner piece and repeat. The idea is to use the puller to provide a constant force trying to separate the flywheel from the crank, but it's the shock of the mallet which dislodges the flywheel from the crank. You need the sudden shock/force to break the flywheel free from the tapered crank.
OK ... me bad ... I just finished removing my flywheel to begin to service a tranny shifting issue and the >real< trick is to hit the puller bolt head with a hammer and NOT the flywheel. 👍
Edited by d2w
