AlanC Posted April 23, 2021 Report Share Posted April 23, 2021 (edited) Before I start pulling things apart, is there any particular order I should try to remove a GG engine from the frame to weld a bit on it? Airbox, exhaust and carb already off. Should the bolts come out in any particular order? Its 26 years old now so I don't want to do something silly and break something that I can't replace. Edited April 23, 2021 by AlanC Quote Link to comment Share on other sites More sharing options...
Creepytheclutchmaster Posted April 24, 2021 Report Share Posted April 24, 2021 Take the radeator air box and skid plate off it makes things a lot easier, sometimes getting the skid plate back on can be a mission if it's been bent in the past . A hydrolic lift stand helps alot. Quote Link to comment Share on other sites More sharing options...
