FeetUp54 Posted April 27, 2021 Report Share Posted April 27, 2021 I have a 08 Beta 125. Runs perfect... untill you put it nose down or nose up. It then changes idle and fouls a plug. Within a matter of seconds. Any ideas? Quote Link to comment Share on other sites More sharing options...
totty79 Posted April 27, 2021 Report Share Posted April 27, 2021 I'd check the float height Quote Link to comment Share on other sites More sharing options...
FeetUp54 Posted April 27, 2021 Author Report Share Posted April 27, 2021 15 minutes ago, totty79 said: I'd check the float height Yes, that is on my to do list today. Someone else looked at it and said it was okay, but ill look for myself. Quote Link to comment Share on other sites More sharing options...
FeetUp54 Posted April 30, 2021 Author Report Share Posted April 30, 2021 On 4/27/2021 at 9:53 AM, totty79 said: I'd check the float height Wasn't the float. I adjusted it to spec and it still fouled. Quote Link to comment Share on other sites More sharing options...
phiggs Posted April 30, 2021 Report Share Posted April 30, 2021 (edited) I think it has something to do with there being a breather hole in the float chamber, which lets neat fuel into the engine, when the angle of the carb is tilted forwards. Maybe this could be modified, or blocked up, but the float chamber still needs to be ventilated somehow. Edited April 30, 2021 by phiggs Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 1, 2021 Report Share Posted May 1, 2021 Take a pic of the carb as it sits. I am betting a vent hose issue. Quote Link to comment Share on other sites More sharing options...
