Automatic Revs
beta_basher
Yeah are you sure you put them floats in the right way round, and that the slide is in the right way round after you took it apart before. If it wasn't doing this before you stripped the carb I would check that first.
Bob
Was it doing this before you stripped your carb down last week beta basher, you were telling me that you'd had some problem with putting it back together, if it wasn't doing this before and has just started after doing this, then thisis more than likely the problem. checking all the rubbers for a good seal might not be a bad idea.
Bob
If the flywheel side crank seals fail, you will suck air rather than tranny oil. This air leak will lead to a lean condition, and therefore high revs. I suspect that it only happens at high revs because there isn't enough vacuum in the crank to pull the air at low revs.
HTH
