Hodaka custom trail 1970
larry s. k.
Motovia  and answer to gas tank , on the gas cap stamped Kerch mf Michigan Wisconsin , , I don’t know if original screw on cap fits leaks a bit  , no other stamps on yellow plastic  , I  have others  tanks ,,same I picked up at bike shop went out of business .there blue in color . Very  cheep to purchase  if you look around standard pump gas does not effect it ,,  This yellow tank came with bike  with cap . Cheers
Thanks Larry!
 Are you sure it's not Keich? I assume they supplied the cap to whoever made the tank.
https://www.kelch.com/products/caps-gauges-and-sensors/
Yes I better clean my glasses . Thanks if you look up Kelch gas caps you can find them on ebay part number 203487 , ,  I have noticed my computer correcting me when I type Kelch , there it did it again , had to  correct it , tipes  ,,  Kerch ,, very strange , any way , , I  still don’t know where  universal yellow fuel tank is mf. . Some one previous quoted ',,,, pacific mf  , there was quite a few I picked up locally , there all blue , scratched ,old inventory most new stock ,  from a motorcycle shop bent bike , sold out store ,   , , cheers
Edited by larry s. k.
2 hours ago, farmer58za said:
Thanks Larry!
Hear  is my spark plug story NGK maby 20 30 hours upon start when cold choke on , fouled out , removed cleaned still would not start ,  checked spark laying on head , kicked over , noticed spark traveling from top to side of spark plug , not electrode , , must burnt I suppose did note have same had  old champion off mopar car looks lot hotter cleaned with emery  installed first kick starts up , ,,, old champion must be 25 years old , in my opinion champion spark plugs rule , will change to proper heat range later , and probably purchase a champion brand ,,, cheers
  • 1 month later...
Thanks  farmer58za ,  I was testing noise reduction , it’s old stile super trap , ,  I removed trap plates , , I ride around  driveway  gravel road ,  down street in woods ,,,, neighbors , just love me  , might change to modern muffler , super trap kind  of racing accessories ,  well , cheers
