AlanC Posted May 13, 2021 Report Share Posted May 13, 2021 Hi folks, Can someone tell me this.. Do shocks wear out on a trials bike? Or since the one I have would need to be drilled, are they like a standard road bike and just fade a bit. Or is the damping that important on them. Its an old Gasgas Thanks Quote Link to comment Share on other sites More sharing options...
eagle8 Posted May 14, 2021 Report Share Posted May 14, 2021 (edited) You need to take the shock off the bike, then take the spring off, push down on shock to see if it has good/ any rebound ? If there is little or no rebound it is definitely time for a rebuild, it depends what sort of & how much riding you do ? I usually rebuild my shocks after about 1k klms of trail bike riding, with a trials bike i suppose you could get a good year out of it, if it has never been touch i would definitely open it up & have an inspection of all parts & reoil & regas it ! Edited May 15, 2021 by eagle8 Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted May 14, 2021 Report Share Posted May 14, 2021 (edited) Yes they ware out in a few ways. Some of them are, that the oil brakes down, the seals ware out, if you loose to much nitrogen it will almost always cause a shock to leak, etc. My 2 cents, for what its worth, is that If the shock is not serviceable but you like the way the bike rides, and your a tight wad, use it tell you feel it doesn't ride nice and replace it, or ride it tell it would normally be time to rebuild and then replace it with a serviceable shock. When mine needed service I decided to change it out for a custom setup that is more plush than my original and really like the way the bike rides now but even just a nice lower cost serviceable shock would work great in my opinion. Good luck with what ever you end up doing. Edited May 14, 2021 by jonnyc21 Quote Link to comment Share on other sites More sharing options...
AlanC Posted May 14, 2021 Author Report Share Posted May 14, 2021 Thanks for the replies folks. Testing the shock with no spring on it would be good idea. But I wouldn't know how much damping it should have in the first place. It's old, and I'm just pottering about on it for fun at the moment. I've did it up a bit, so I'll try it and if it has no grip and can't get up the hills, I'll know its the shock as its the only thing I haven't done. Quote Link to comment Share on other sites More sharing options...
cascao Posted May 15, 2021 Report Share Posted May 15, 2021 No misteries rebuilding these standard shocks 1 Quote Link to comment Share on other sites More sharing options...
mcman56 Posted May 17, 2021 Report Share Posted May 17, 2021 Nice video. Where can you get the rebuild parts? Quote Link to comment Share on other sites More sharing options...
cascao Posted May 18, 2021 Report Share Posted May 18, 2021 Bought from parker store downtown. Others seal and hydraulic gasket stories can have these seals too. Quote Link to comment Share on other sites More sharing options...
Simba Posted June 30, 2021 Report Share Posted June 30, 2021 I do what eagle8 said. I remove the spring, and put the comp and rebound adjusters in mid position. It should take a bit of force to compress the damper (your working against the gas pressure and oil damping). When you release the damper it should return in a firm controlled manner. You can play with the adjusters and notice a change in damping rate Quote Link to comment Share on other sites More sharing options...
