Olitrs300 Posted May 19, 2021 Report Share Posted May 19, 2021 Hi, I recently noticed my clutch on my 2018 trs rr is overly heavy compared to other bikes. On inspection of the clutch pack it measures 9.8 which is just below spec but should make it lighter if anything. The finger height is under spec at 12.7. Anyone have any idea what is wrong and how to fix it? cheers Quote Link to comment Share on other sites More sharing options...
Intotrials Posted May 20, 2021 Report Share Posted May 20, 2021 A mate of mine has just had a brand new 2021 250 TRS RR and the clutch is heavy on that compared to my gas gas and other modern bikes I've ridden. This was one of 2 things that puts me off having a TRS; 1 -heavy clutch, 2 - stearing on tight corners the front wants to wash out. Other than that, nice bike. 1 Quote Link to comment Share on other sites More sharing options...
Olitrs300 Posted May 20, 2021 Author Report Share Posted May 20, 2021 Yes I’ve heard the clutch on them is heavier than other bikes, however comparing mine to another 2018 rr (identical bike) mine was much heavier which leads me to believe that somethings wrong with it. What that may be I do not know though! Quote Link to comment Share on other sites More sharing options...
baldilocks Posted May 20, 2021 Report Share Posted May 20, 2021 What I never understand with the clutch pack measurements is how hard you are supposed to squeeze the vernier guage ? 9.85 mm is the ideal but depending how strong you are and the amount of oil on the plates you can get 0.5mm difference? Difficult to measure without disassembly Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 23, 2021 Report Share Posted May 23, 2021 (edited) On 5/20/2021 at 5:31 AM, Intotrials said: A mate of mine has just had a brand new 2021 250 TRS RR and the clutch is heavy on that compared to my gas gas and other modern bikes I've ridden. This was one of 2 things that puts me off having a TRS; 1 -heavy clutch, 2 - stearing on tight corners the front wants to wash out. Other than that, nice bike. That`s an under statement. It washes out in the ruble unexpectedly. I got to section 8 at a low traction trials 2 weekends ago, drove straight back to the pits and put a for sale sign on it and it was gone in 24 hours. Edited May 23, 2021 by lineaway 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 23, 2021 Report Share Posted May 23, 2021 On 5/20/2021 at 7:23 AM, Olitrs300 said: Yes I’ve heard the clutch on them is heavier than other bikes, however comparing mine to another 2018 rr (identical bike) mine was much heavier which leads me to believe that somethings wrong with it. What that may be I do not know though! The higher the fingers, the lighter the feel. They also make a soft retainer ring, see your dealer. The type of oil can make a difference too. Nils Clutch trial is an improvement or your m/c could use a rebuild kit. Quote Link to comment Share on other sites More sharing options...
Intotrials Posted May 31, 2021 Report Share Posted May 31, 2021 Why are they so noisy also? gas gas have always had a reputation for noisy clutches, but they work well and operate really light and smooth so you sort of get used to the noise. The new TRS are not only heavy but execssively noisy, its very annoying! Quote Link to comment Share on other sites More sharing options...
nickfox Posted September 18, 2021 Report Share Posted September 18, 2021 yea I have the same issue, 2020 TRS 250. Clutch is smooth but a strain on my skinny finger. Is there any good guides to adjust the clutch a bit lighter? they must have beefier springs compared to other models then? Quote Link to comment Share on other sites More sharing options...
Assgas Posted February 3, 2024 Report Share Posted February 3, 2024 (edited) Order this soft clutch ring PT # 05024MT100 Makes it a smoother pull Edited August 29, 2024 by Assgas Quote Link to comment Share on other sites More sharing options...
Assgas Posted November 22, 2024 Report Share Posted November 22, 2024 I have found that the TRS uses the same clutch plates and Belville spring as Gasgas I took the belville spring and made it thinner and it made a huge difference now its smooth like my old Gasgas Quote Link to comment Share on other sites More sharing options...
lemur Posted November 22, 2024 Report Share Posted November 22, 2024 Shorty lever moved way in on the bars gives you greater leverage and friction zone range. Also makes it impossible to jam your fingers behind the levers. Highly recommended setup to make the lever pull lighter. Quote Link to comment Share on other sites More sharing options...
Assgas Posted November 22, 2024 Report Share Posted November 22, 2024 I found these Zeta levers The wife and I love these very adjustable they spring forwards to avoid braking them the machine work are excellent Do research on were to buy them https://shopotam.com/en/p-zeta-pivot-cp-ze42-3185-ajp-trial-gg-short-clutch-lever-V153318988?srsltid=AfmBOopFwUsPdpIiR9qdfZp4BF0qEIQ1IVyiNosYHM0JRCdNHYvmDZaE Quote Link to comment Share on other sites More sharing options...
Assgas Posted November 22, 2024 Report Share Posted November 22, 2024 9 minutes ago, Assgas said: I found these Zeta levers The wife and I love these very adjustable they spring forwards to avoid braking them the machine work are excellent Do research on were to buy them https://shopotam.com/en/p-zeta-pivot-cp-ze42-3185-ajp-trial-gg-short-clutch-lever-V153318988?srsltid=AfmBOopFwUsPdpIiR9qdfZp4BF0qEIQ1IVyiNosYHM0JRCdNHYvmDZaE Zeta part numbers clutch ZE-3185 brake ZE41-3185 Quote Link to comment Share on other sites More sharing options...
