MrToad Posted May 23, 2021 Report Share Posted May 23, 2021 Hope It's not a bother, but could someone post a photo of their chain oiler adjustment screw? I've put in about 4 hours trying to make one that will seal up when tightened down. Does it have a tapered seat, or like a carb air screw? I've flushed it out and installed a screw just to keep water and dirt out for now. I know there are suppose to be no such thing as a stupid question so if I become a distraction let me know. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 23, 2021 Report Share Posted May 23, 2021 (edited) If you do get it to work, you will discover it oils the chain, rim, tyre, mudguard and your back...... Edited May 23, 2021 by b40rt 2 1 Quote Link to comment Share on other sites More sharing options...
pschrauber Posted May 23, 2021 Report Share Posted May 23, 2021 On 5/23/2021 at 7:56 AM, b40rt said: If you do get it to work, you will discover it oils the chain, rim, tyre, mudguard and your back...... Expand That states all you need to know, even in very very muddy events they would not make sense as you emberass the environment with them. A solution still clogging not only the chain but too the rest of the bike would be chain oil on wax or PTFE basis that is at least easy to wipe away and works quite good, a drop each minute I would think is all you need. 1 Quote Link to comment Share on other sites More sharing options...
shakennstirred Posted January 18, 2022 Report Share Posted January 18, 2022 yes its tapered . one for sale on ebay, by the beamish owner club Suzuki Exacta/Beamish/RL250/RL325. Oil Drain Plug. Swing Arm. 61274-38000. | eBay Quote Link to comment Share on other sites More sharing options...
