Queestce Posted May 28, 2021 Report Share Posted May 28, 2021 (edited) G'day all, I'm a complete beginner to trials. Very keen to get a bike and learn. Not to compete at this stage, but to develop better off road handling skills. I have an adventure bike and I spend too much time picking it up 😂 I am planning to look at an early 2000s Scorpa SY250 tomorrow. It's been stored for quite a while but looks quite tidy. Aside from the generic used bike checks I wondered if anyone on here might have some specific SY knowledge and be able to point me towards common issues I should be on the lookout for? Maybe trials bike specific things I should check out? Any information would be very much appreciated! Very keen to hop onboard. Thanks all, Tk  Edited May 28, 2021 by Queestce Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 28, 2021 Report Share Posted May 28, 2021 Common issues are: Bent or cracked clutch actuator arm. Split mid section of the exhaust. Quote Link to comment Share on other sites More sharing options...
pauls320 Posted May 28, 2021 Report Share Posted May 28, 2021   1:The rubber seal under the choke ...plunger.., can decompose or get hard and fail to seat causing rich running condition even with choke ''off''. 2: Many parts are getting hard to source. It is still a good machine, good luck Quote Link to comment Share on other sites More sharing options...
Queestce Posted May 29, 2021 Author Report Share Posted May 29, 2021 Thanks guys. I'll be checking this out in a couple of hours so will look for those two. Quote Link to comment Share on other sites More sharing options...
jtrials31 Posted June 10, 2021 Report Share Posted June 10, 2021 On 5/28/2021 at 11:40 AM, pauls320 said:   1:The rubber seal under the choke ...plunger.., can decompose or get hard and fail to seat causing rich running condition even with choke ''off''. 2: Many parts are getting hard to source. It is still a good machine, good luck Do you know a source for that seal? I think mine may have done that. Quote Link to comment Share on other sites More sharing options...
pauls320 Posted June 11, 2021 Report Share Posted June 11, 2021 If yours is indeed not sealing anymore, you will probably have to dig it out the old one and source some Viton rubber in same thickness ( old one may have shrunk a little) and punch out a new one from the stock.  Quote Link to comment Share on other sites More sharing options...
