Divouneh Posted June 4, 2021 Report Share Posted June 4, 2021 Hello The bike, the first target is to start the engine with a clean carburetor / exhaust and of course wheels (Tires/ spokes). I will manage to have a Vermont registration : its's means lights, horn with probably a new ignition with 12 volts supply. A long way to go 😪 2 Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 8, 2021 Author Report Share Posted June 8, 2021 Today I cleaned up the rear wheel, waiting the spoke to replace the 2 broken one. I also got the tires at a fare price (105 USD). Question: the gears are in left side, how are they working : 1N2345 or 54321N ?🤨 Thank you Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 8, 2021 Report Share Posted June 8, 2021 first gear is at the bottom Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 8, 2021 Author Report Share Posted June 8, 2021 Thank you... 😉 Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 13, 2021 Author Report Share Posted June 13, 2021 Today job: Kickstand... The kickstand was broken and the shaft rusted inside. I had to cut it and to do a new pivot. I need to find a spring: Could you give me the size from the original one 😉? Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 13, 2021 Author Report Share Posted June 13, 2021 Other item is the exhaust, my is badly cut 🤮 I found a cheap one in UK, to repair the old one is possible however the final cost will be the same (Welding, sand blasting, painting....). Wait and see... Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 21, 2021 Author Report Share Posted June 21, 2021 I received the exhaust and it will fit, the fork tubes are difficult to slide out of the clamps 🥴 . Top end is schedule for this week, it will give me a good overview from the engine status 🙂. I bought this table in Ebay: Powerstands Racing POWERPLATFORM Powerplatform Portable Work Table. A good deal and easy to store when not in use... Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 21, 2021 Author Report Share Posted June 21, 2021 Question: The nut from the flywheel seems not correctly in place ? Thanks for the advices 😏 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 22, 2021 Report Share Posted June 22, 2021 20 hours ago, Divouneh said: Question: The nut from the flywheel seems not correctly in place ? Thanks for the advices 😏 Yes that's the normal arrangement 1 Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 22, 2021 Author Report Share Posted June 22, 2021 The front wheel is clean outside, I need to remove and inspect the brake and the speedo connection 🙂... Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 22, 2021 Author Report Share Posted June 22, 2021 Carburetor is ready for inspection, the plate to keep the cable in place is missing 😔... Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 23, 2021 Author Report Share Posted June 23, 2021 The missing part (could be done locally) 😏 Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 25, 2021 Author Report Share Posted June 25, 2021 After investigations, it seems some Amal have no plate to keep the cable in place. no one has had such issue ?🙄 Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 25, 2021 Author Report Share Posted June 25, 2021 Broken screw, the one to keep the rear shock in place 😪. The others one are removed. I will try to drill it with a "reverse" bit later, it's not a big issue.. Quote Link to comment Share on other sites More sharing options...
Divouneh Posted June 25, 2021 Author Report Share Posted June 25, 2021 Engine is out 🙂, I wish to open it asap but the frame is the priority... 2 Quote Link to comment Share on other sites More sharing options...
