MAL1980 Posted June 8, 2021 Report Share Posted June 8, 2021 Hi Does anyone know how to explain the setup of the front Tech shocks and rear Reiger 1 way shock setup on the TRS One R (2021). I’m a heavier rider and would like to know ideal settings to start with and then I can adjust from there. Please dumb it down for me. 😂 Thanks in advance. Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 9, 2021 Report Share Posted June 9, 2021 (edited) If you are a heavier rider you need to go up at least 2 steps in the rear spring. See your dealer . You can leave the front spring alone until about the 240 lb and up. Edited June 9, 2021 by lineaway 1 Quote Link to comment Share on other sites More sharing options...
MAL1980 Posted June 9, 2021 Author Report Share Posted June 9, 2021 Thanks @lineaway, I have the right spring it was more how to set the adjusters and what range is best. 🙂 1 Quote Link to comment Share on other sites More sharing options...
