triumph cub
FISCHBACH
Nicolas,
you don’t really need an R Cam for trials as they make the motor have less traction and response from low revs.
However I have R cams fitted to both of my trials Cubs because I wanted slightly more power.
If you do fit an R cam (if you can find one!) you will need different valve clearances.
It is possible to fit a distributor type camshaft into a side points engine if you carry out some modifications
Hope this helps
Bruce.
Edited by brucey
typos
I run my  cub with the standard cam as I found it harder to start and if going over a ridge where you shut off it would stall I built the engine in a verity of specs High comp pistons low comp pistons with and without the R cam I run high comp piston standard cam If can climb Scottish hills it is fine
