2003 gas gas 280 crank seals
Tacton
Just a quick question before I put my engine back together, I’m asking just to double check because I have a feeling that someone else has split the case before me, anyways I’m just wanting make sure the crank seals are in the proper way,
is the proper way to have the spring inside the seal towards the crankshaft, there’s three seals all are internal with one on the clutch side and two on the mag side please correct me if I’m wrong thanks
