Rear brake issue
Sum
Hi all,
I have ridden my 2020 GasGas 280 for about 50 hours and the rear brake became less effective with squeaking noise.
The brake pads seem to have life left.
I would appreciate your thought about it. Should I change the pads? Or brake fluid? Or clean the surface of the pads and disc?
thanks,
23 hours ago, Sum said:
Cold water?
Some people advocate dragging the brake to get it really hot, and then throwing cold water over it.
Personally I would take out the pads and rub the friction surfaces on a piece of 180 grit wet'n'dry. Then run the wet'n'dry on the disc. Then clean both with brake cleaner before reassembling.
