Black engine 250 carb change
turps
I know it's been asked before but not seen an answer. I recently put an OKO carb on my Cota with great results and was thinking about doing the same on my Beamish. Has anyone done this and what were the results ? cheers
I seem to remember someone fitting an OKO carb to an RL250 , but cant remember if it was on here or another forum.
As it was an RL250 not a beamish , it may have been someone in the USA or Aus , NZ etc. ?
A job for Google perhaps ?
Failing that you could try your Cota carb on the Beamish as it is and see if it works okay, { they are both 250cc piston port 2 strokes , so similar engines } - if okay then use the same jetting / settings as a starting point and fine tune later
  • Like 2
  • Thanks 1
