Steeley Posted August 29, 2021 Report Share Posted August 29, 2021 I am looking to put a tiger cub swinging arm on my bantam to give a bit more clearance i can find two part no’s F4070 and F4598 which would be correct for d14 / 175 frame thanks Quote Link to comment Share on other sites More sharing options...
naichuff Posted August 29, 2021 Report Share Posted August 29, 2021 I have two cubs One swinging arm I am unsure of sorce The other came from FEKED A cub one the tubes come from the pivet points at an angle and bend straight half way down The FEKED the tubes are straight all the way and sit outboard of the pivit points to allow the 400 tyre to fit Quote Link to comment Share on other sites More sharing options...
Steeley Posted August 31, 2021 Author Report Share Posted August 31, 2021 Thanks naichuff the feked one looks great but a bit out of my price range I have managed to pick up a Tiger cub sports arm which is wider than the bantam one and should be a straight swap Quote Link to comment Share on other sites More sharing options...
andy m Posted August 31, 2021 Report Share Posted August 31, 2021 What sub frame are you using ??/ Quote Link to comment Share on other sites More sharing options...
Steeley Posted September 1, 2021 Author Report Share Posted September 1, 2021 standard bantam sub frame but it will be modified for mudguard and may need narrowing at the top to give better space between thighs Quote Link to comment Share on other sites More sharing options...
