Davybull072 Posted September 3, 2021 Report Share Posted September 3, 2021 Just about to start rebuilding my 2001 GasGas TXT 249. It has been sat in a shed for 10 years so need quite a bit of work. First job is going to be the brakes. Both calipers are Hebo and sticking so not working right. I believe that neither the caliper of the repair kits are available. Any solutions? Cheers. Dave. Quote Link to comment Share on other sites More sharing options...
reggie Posted September 6, 2021 Report Share Posted September 6, 2021 Find an AJP or Beta (grimeca) front caliper this will bolt on with very few issues. On the rear , I believe that there is a retrofit assembly available, I do not remember where I have seen it on the internet. Good luck. Quote Link to comment Share on other sites More sharing options...
reggie Posted September 6, 2021 Report Share Posted September 6, 2021 Apparently you need the complete rear brake system from a 1997 Gas Gas Quote Link to comment Share on other sites More sharing options...
Davybull072 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Cheers Reggie, I will look into it. I might have sorted the front and I know that there is a retrofit AJP for the rear if I need it although it is a bit pricey. Dave. Quote Link to comment Share on other sites More sharing options...
Davybull072 Posted September 8, 2021 Author Report Share Posted September 8, 2021 Front working perfectly but the rear caliper is scrap I'm afraid. Can't find one second hand and no-one seems to have the conversion kit anymore. DAMN! Quote Link to comment Share on other sites More sharing options...
turbofurball Posted September 9, 2021 Report Share Posted September 9, 2021 The best option, then, is probably to get any other trial back caliper and get an adapter machined up to make it fit ... time to get creative Quote Link to comment Share on other sites More sharing options...
totty79 Posted September 9, 2021 Report Share Posted September 9, 2021 In what way is it scrap? If the pistons aren't too pitted and the seals haven't perished or torn you might get away with a clean polish and rebuild without a repair kit. Sourcing seals and pistons by size is a pain but can be done, you can also have pistons machined. Quote Link to comment Share on other sites More sharing options...
Simba Posted September 10, 2021 Report Share Posted September 10, 2021 All you need to do is google brake caliper seals, for the brake piston diameter you have. All caliper piston seals are square profile. I have also done this with brake pistons. I recently rebuilt an old hebo caliper, none of the parts I used were listed hebo parts. 1 Quote Link to comment Share on other sites More sharing options...
Andy B Posted March 17, 2022 Report Share Posted March 17, 2022 Hi Simba, Could you remember where you sourced the seals for the rear hebo caliper? I'm drawing a blank and have even sent the caliper to seal specialists and they can't find a seal to suit. Cheers, Andy. Quote Link to comment Share on other sites More sharing options...
