JonnyWobbles Posted September 6, 2021 Report Share Posted September 6, 2021 Hi, I’m just recommissioning a 2004 Rev 3 that’s been laid up for a number of years and could do with some clarification with respect to how to correctly set the chain tension. The manual shows 20mm gap from the top of the chain tensioner to swing arm. Not easy as my tensioner is a bit skew-if, and is this with the bike supported on a centre stand, on the ground or loaded etc.? Searching for an answer throws up various methods and suggests tension should be set with the axel / swing arm pivot / front sprocket aligned i.e. effective maximum length. Any help as always gratefully received! Cheers Quote Link to comment Share on other sites More sharing options...
markparrish Posted September 8, 2021 Report Share Posted September 8, 2021 I adjust mine with it on the side stand and use a thick finger rather than precise 20mm measurement, but this seems to be ok and I don't think the chain is over-stretched when suspension is fully loaded. Quote Link to comment Share on other sites More sharing options...
