315 Clutch Fix Fyi
donmurray
My 315 had a clutch that dragged so bad you had to push off and then click it in gear when it was cold/first started. Then after it warmed the it would drag badly unless you blipped the throttle every 3 seconds. Also hard to modulate. Tried the Silkolene oil, but not better. I finally bit the bullet and installed new standard friction disk which are a mix of cork and paper fibre. Also went to the recommended Elf oil. Just to make sure I bleed the hydraulics. Clutch works fine now. A little clunk as it goes in gear, but the bike does not move. Smooth progressive engagement. It now has about 3 hours since the rebuild and still works fine.
