mark ty 1111 Posted October 17, 2021 Report Share Posted October 17, 2021 I have a ty 175 Iam having a problem when pushing in the choke on the carburetor it is reving very highly rather than reving lower could anybody please advise iam a novice when it comes to bikes Quote Link to comment Share on other sites More sharing options...
PakJeem Posted October 17, 2021 Report Share Posted October 17, 2021 (edited) The choke richens the mixture for starting. Pushing it back in lets in more air, leaning out the mixture. So you have a lean surge condition. You need more fuel or less air. To rectify, try turning the air screw in (clockwise). That will let less air in at idle. Try turning it in quarter turn increments. Normal range for the air screw is 1.5 turns out (counterclockwise) from fully closed. If the air screw likes to be less than one turn out, then go up one size on the pilot jet to allow more fuel at idle. it’s also possible you have a torn carb boot which is letting air slip by, creating the lean condition you describe. But more likely you just need to richen the air screw for your climate, and possibly the pilot if the air screw isn’t enough. Edited October 17, 2021 by PakJeem Quote Link to comment Share on other sites More sharing options...
mark ty 1111 Posted October 18, 2021 Author Report Share Posted October 18, 2021 Thanks very much for the information I will try this at the weekend much appreciated Quote Link to comment Share on other sites More sharing options...
