Chris87trs Posted October 24, 2021 Author Report Share Posted October 24, 2021 11 minutes ago, Nishijin said: Eggs sucking here… on the outside of the carb, are you definitely turning the air/fuel screw in the right direction? Sometimes people forget which side of the carb the screw is on and what it means. You might be adding air/reducing fuel when you think you are adding fuel/reducing air. Mine was running so rich it would foul the plug and bog out. Even leaned out a bit, it has that black plug. I’d turn your air-fuel mix all the way in, counting how many turns you had it at, then report back. Yea the photo of the plug is when it was half a turn out on the air screw Quote Link to comment Share on other sites More sharing options...
