rick1962uk Posted October 24, 2021 Report Share Posted October 24, 2021 hi im just refreshing the scorpa for a trial soon but noticed the fuel hose is rock hard and shrunk so going to replace but tank side has a 90 degree bend and looks tight to the tank has anyone used straight hose and got away with it many thanks rick Quote Link to comment Share on other sites More sharing options...
Stomp Posted October 26, 2021 Report Share Posted October 26, 2021 Pretty rare bike these days! I had one way back and the route from tank to carb was a pain. All I can mind is the length was important to stop it kinking. Best of luck. Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted October 26, 2021 Report Share Posted October 26, 2021 I've got an SR 280 - fine bike, does all I need. Removing/replacing tank is a bit fiddly due to fitting fuel pipe to petcock where outlet points inwards. Could swap for one where outlet points downwards so pipe is easily detached, easily and at low cost. Quote Link to comment Share on other sites More sharing options...
rick1962uk Posted November 4, 2021 Author Report Share Posted November 4, 2021 Many thanks got it sorted droped the carb inlet a bit used 5mm fuel pipe for trials bikes and it went rond realy well ONE WORD OF WARNING to anyone with black pipe the new E10 fuel had eaten it alive the inside has rotted away almost filling the fuel filter Quote Link to comment Share on other sites More sharing options...
