midlife Posted October 27, 2021 Report Share Posted October 27, 2021 What is the easiest electronic ignition to fit to my T20 cub. Its the older one not the one with the points on the side. Quote Link to comment Share on other sites More sharing options...
naichuff Posted October 27, 2021 Report Share Posted October 27, 2021 I have two cubs one uses Electrix world mounted on the outer clutch case The other mounted on pillars fitted to the crank case The first one is a little tricky to set up But both work fine I have used the PVL system also mounted on the pillar Quote Link to comment Share on other sites More sharing options...
