rrefugee Posted November 2, 2021 Report Share Posted November 2, 2021 I have a 2015 Scorpa twenty 300 that has started leaking at the fork seal. No biggie, they are probably the seals installed at the factory. What weight of fork oil should I use and how much oil goes in each leg? Quote Link to comment Share on other sites More sharing options...
cascao Posted November 2, 2021 Report Share Posted November 2, 2021 If your scorpa has tech forks: 1 Quote Link to comment Share on other sites More sharing options...
rrefugee Posted November 3, 2021 Author Report Share Posted November 3, 2021 5 hours ago, cascao said: If your scorpa has tech forks: How do I tell if it has tech forks? Quote Link to comment Share on other sites More sharing options...
rrefugee Posted November 4, 2021 Author Report Share Posted November 4, 2021 I found an owners manual online. For my bike, it said to use 5W fork oil with 115 mL on the spring leg and 55 mL on the shock leg. Quote Link to comment Share on other sites More sharing options...
magnapoxy Posted November 4, 2021 Report Share Posted November 4, 2021 here is a good site about the weights & viscosity indexes of assorted brands of suspension fluids. www.peterverdone.com.. myself, in forks its motorex. in showa shocks, its Silkoline Pro RSF 2.5 wt. I change these fluids often. 1 Quote Link to comment Share on other sites More sharing options...
