My Montesa Will Not Run!
sam
I'm trying not to panic, but I can not get my Hontesa to start and I'm leaving for Motorama in the morning! B)
I pulled the carb and cleaned it last night, there was dirt visable in the intake side! I simply ran some fine wire thru the jets but did not remove them, used some carb cleaner also.
I went home at lunch today and poured a little amount of fuel in the cylinder and she fired up for a moment!
The symptoms that lead to this: After 7 hours of riding this week she started not to idle then pinging, or a slight knock as she tryed to idle, diesaling affect.
any suggestion would be greatly appreciated! :)
sam
You guys will laugh at this one!
I was frantic to get this bike running and yes the first problem was a dirty carb, but then I kept putting one of the floats in upside down! :)
You must understand hoosier hillbillys! B):P:P;)
