tractorman Posted December 20, 2021 Report Share Posted December 20, 2021 Hello all first time post i have a montesa 348 had nearly a year had all sorts of problems, getting it sorted slowly but one thing i"m having trouble with is the clutch side crank seal done it twice and it"s still leaking sucking clutch case oil has measured the crankshaft this time and it"s worn down to 24.7mm has anybody used a SKF speedi seal on a crankshaft. thanks in advance Pete. Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted December 20, 2021 Report Share Posted December 20, 2021 I've used a Speediseal in the water pump of a marine engine. It had run up more hours than the original shaft without wear when I sold the boat. So I would count that as a success. Quote Link to comment Share on other sites More sharing options...
tractorman Posted December 21, 2021 Author Report Share Posted December 21, 2021 Hi traprezeartist thanks for the reply that sound good, i was just wondering weather it wood want some sort of adhesive to bond it to the crank to keep the crankshaft pressure in. Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted December 21, 2021 Report Share Posted December 21, 2021 I wouldn't have thought so as the speediseal is a press fit. I didn't have any water leakage with mine. Quote Link to comment Share on other sites More sharing options...
