bullylover Posted March 31, 2022 Report Share Posted March 31, 2022 They are as rare as Rocking Horse Poo! Get your old one welded up. 2 Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted March 31, 2022 Report Share Posted March 31, 2022 As has been said before the Bultaco alloy is of good quality and can be welded. If you are going to paint them black then the dressing of the weld is not as important. If you are polishing them, then obviously more effort is required which is half the fun of restoring a classic bike and the end result should put a smile on your face since you have done it yourself. 1 Quote Link to comment Share on other sites More sharing options...
slowrider Posted March 31, 2022 Author Report Share Posted March 31, 2022 1 Quote Link to comment Share on other sites More sharing options...
slowrider Posted April 2, 2022 Author Report Share Posted April 2, 2022 Was not all that impressed with the quality of the reproduction fiberglass airbox and wanted to use the factory one, but it was badly cracked. Decided I had nothing to lose and heated up the end of a chisel and tried welding up the box with surprising results. not pretty, but solid and since its out out site it worked quit well! Quote Link to comment Share on other sites More sharing options...
