mikeg135 Posted January 3, 2022 Author Report Share Posted January 3, 2022 (edited) 1 hour ago, lineaway said: So since you have done everything, again. How are the vent lines routed? if you meant the overflow fuel lines from the carb, they are hanging straight down and clear....the crank case vent line located near the front sprocket it makes an upside "U" and ends up just above the front sprocket, it is also is clear. those are the vent lines I am aware. I want to ride it a bit more before taking off the exhaust and doing a burn, but this rain in the GA has my yard a muddy mess Edited January 3, 2022 by mikeg135 1 Quote Link to comment Share on other sites More sharing options...
Assgas Posted November 18, 2023 Report Share Posted November 18, 2023 On 1/1/2022 at 8:31 PM, mikeg135 said: I saw a video of someone using a heat gun to cook out the middle box...is that the normal process Put it on the BBQ she will smoke real bad when it quits smoken it done Quote Link to comment Share on other sites More sharing options...
