Robonthemoor Posted January 22, 2022 Report Share Posted January 22, 2022 It as a 10T on the front, 42T on the rear, what do you guys use tooth wise? it was my first ride today and it was a little high geared! your input would be most welcome. Thanks in advance Quote Link to comment Share on other sites More sharing options...
pjw123 Posted January 23, 2022 Report Share Posted January 23, 2022 Its a fairly common situation across all makes, largely based on riders own personal preferences. I use 9 tooth front sprocket to make a 300 Beta easier to ride. To lower the gearing, a general guidance is : drop a tooth on front sprocket, (you will get a similar result by going up 4 teeth on the rear). Front sprocket cheaper & quicker option. (less likely to have to mess around with your chain length). You will notice a difference, & 2nd gets used a bit more often. 1 Quote Link to comment Share on other sites More sharing options...
jsp Posted January 24, 2022 Report Share Posted January 24, 2022 i personally don't mess with the gearing, but I do ride 90% of the time in first gear. but I know a couple of lads that drop the rear sprocket down to a 41t but you'll need to remove the half link out of the chain 1 Quote Link to comment Share on other sites More sharing options...
