kawasarki Posted February 18, 2006 Report Share Posted February 18, 2006 Hello , Can anybody suggest the correct length spokes to use to offset the rear tiger cub wheel when used in a C15. I've already been told that a bantam hub would have been better but i would like to keep the Cub Hubs. Many thanks Mark. Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted February 18, 2006 Report Share Posted February 18, 2006 (edited) Give Millers a ring they fit cub hubs, widened, to their B40 bikes so should know the lengths. The Bantam hub would have been better because it's wider. The normal mod is to saw the hub in half insert a band and weld back up again. Personally i feel too much trouble so i bought some billet alloy ones. Expensive but lighter and much much stronger as made in one piece from aircraft grade alloy. Only problem when using Cub hubs is because they are narrow when used in a C15 rear swingarm one side has the spokes almost vertical and as such is a weak area. Might be worth having yours widened before you rebuild the wheel Edited February 18, 2006 by Old trials fanatic Quote Link to comment Share on other sites More sharing options...
kawasarki Posted February 19, 2006 Author Report Share Posted February 19, 2006 Many thanks OTF for your advice , but the wheel came already in the bike & is set wrong in the frame ( wheels not in line ). How much are the billet hubs & who supplies them ? Also do you know if B25 forks are any better than WD B40 forks ? ( we have B25 in the bike ). Regards Mark. Quote Link to comment Share on other sites More sharing options...
triton Posted February 20, 2006 Report Share Posted February 20, 2006 I had my cub rim offset to obtain clearance between tyre and chain guard, it was always clogging with mud/leaves etc. To do this the hub was widened by half inch by welding in a spacer, otherwise the the righthand spokes would be almost vertical, they must angled for strength. This left the wheels out of line, which I can live with as I dont need an mot. I also fitted a spacer between hub and sprocket for additional clearance. Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted February 20, 2006 Report Share Posted February 20, 2006 Kawasarki i got my hubs from Alan Whitton 01246 419805. They will probably cost you in the region of around Quote Link to comment Share on other sites More sharing options...
kawasarki Posted February 20, 2006 Author Report Share Posted February 20, 2006 Many Thanks for the replies. I think the fork mods are out of my pocket range at the moment , my mate & me are very new to this game ( As in never ridden a trial yet ) but i 've done a lot of MX , Trail , Enduro. I 've been reading Sammy Millers 'Clean To The Finish ' & Don Morley's Classic British Trials Bikes for inspiration & it's a whole different ball game. I do hope i've got the same enthusiasm once i've ridden a trial.Once again many thanks for the Advice regards Mark. Quote Link to comment Share on other sites More sharing options...
unclebuck Posted March 21, 2006 Report Share Posted March 21, 2006 I have a pair of Cub hub trials wheels for sale. Professionally widened rear hub and pro lightened front hub Quote Link to comment Share on other sites More sharing options...
fast ferry Posted March 21, 2006 Report Share Posted March 21, 2006 Hello Uncle Buck, I would like to buy your Cub wheels, please be so kind to e-mail me : ferryfast@hotmail.com Quote Link to comment Share on other sites More sharing options...
unclebuck Posted March 22, 2006 Report Share Posted March 22, 2006 (edited) Fast Ferry - You Have Mail (with pics) Edited March 22, 2006 by unclebuck Quote Link to comment Share on other sites More sharing options...
fast ferry Posted March 23, 2006 Report Share Posted March 23, 2006 Hello UncleBuck, Thanks, give it a thought and my reply will be this friday Ferry Quote Link to comment Share on other sites More sharing options...
