Pioletblau Posted February 20, 2022 Report Share Posted February 20, 2022 Hello, I got this forks for Tiger Cub, Marzocchi 34 mm, guess on Norton sliders. Modified Cub yokes. Lenght from wheel spindle to top of stanction 28.7 "/730 mm. The bike has original frame. I would need help about changing oil, because i feel them too slow. What type, 5w or 10w, and what volume in each fork? My weight is 154 lb (75 kg). Many thanks!!! Quote Link to comment Share on other sites More sharing options...
millwright Posted February 22, 2022 Report Share Posted February 22, 2022 Try 5w and raise the level a little it will soften them up and the raised level will help stop them bottoming out. Quote Link to comment Share on other sites More sharing options...
teamferret Posted February 22, 2022 Report Share Posted February 22, 2022 I would say 5W too. Start by taking out the springs and filling with oil until 175mm from top Quote Link to comment Share on other sites More sharing options...
Pioletblau Posted February 22, 2022 Author Report Share Posted February 22, 2022 Hello, Many thanks for the advice. I understand levelling the oil with the forks bottomed, and then adjusting the caps with the forks extended. Best, Quote Link to comment Share on other sites More sharing options...
