90 Degree Feeler Gauges for 4t
mcman56
It is not easy to use standard bent feeler gauges for valve clearance inspection and I would think a 90 degree bend would work better.  Has anyone found 90 degree gauges in the correct size?  I found some sets used for big diesel engines but the smallest is 0.008" and they are needed down to 0.004" (0.1 mm).  There are some straight brass gauges.  Do they bend better than stainless steel?
