Birdman Posted April 8, 2022 Report Share Posted April 8, 2022 I have a 08 Rev 3 250 and I took the clutch apart to check the disks and basket. I have everything put back together but when I work the leaver it is super hard and it's not lifting the pressure plate to disengage the clutch. Does anyone have any idea what it is? Quote Link to comment Share on other sites More sharing options...
gasgasman280- Posted April 8, 2022 Report Share Posted April 8, 2022 (edited) It time to go recheck your work again. You have most likely screwed up your reassembly of the clutch Edited April 8, 2022 by gasgasman280- Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted April 9, 2022 Report Share Posted April 9, 2022 Probably have the pack in backwards or out of order. Maybe you flipped the pack around 180 by mistake? Quote Link to comment Share on other sites More sharing options...
overdale Posted April 9, 2022 Report Share Posted April 9, 2022 When you took the clutch apart, was the bike lying on it's side or upright and did you take the clutch lifting pushrod out of the centre of the shaft? The reason I ask is that there is a 5 or 6 mm ball inside that shaft between that pushrod and the slave cylinder mechanism. If that is missing (on your garage floor!), you would lose that amount of lift, the slave cylinder would operate to it's full travel then go solid and the push rod would not lift the pressure plate. For assembly of the of the clutch go to the Beta UK website, parts finder, select any Rev-3 model, select clutch and you can see the bits. Let us know what you find. 5 Quote Link to comment Share on other sites More sharing options...
Birdman Posted April 10, 2022 Author Report Share Posted April 10, 2022 I lost the ball thanks man I never even seen it come out. I've never seen a clutch with 2 all my other bikes only have one at the slave cylinder. 2 Quote Link to comment Share on other sites More sharing options...
