315r showa fork tool
Tristan
Hi, im servicing my 315 showa forks. I have removed the various parts and now need the special tool to split the upper and lower tubes. I've searched the honda part number for the special tool but it is discontinued. Can anyone point me in the direction to a tool that will do the job, or if not I'm thinking a nut welded onto a piece of bar. Tia
What do you mean split upper and lower tubes?
Undo the dust caps and security rings of the oil seals. Unscrew the piston at the bottom and get all lose parts out from the top. And them pull them **** them apart?! You'll need a few harder ones...
I have a Paoli in mine but the system should be the same?!
