garydwall Posted May 4, 2022 Report Share Posted May 4, 2022 Hello can someone please advise me. I have my engine split to replace the crankshaft bearings. The crankshaft is stuck in the flywheel side of the casing. I've tried a tap with a rubber hammer but no joy. Any suggestions greatly appreciated. See pictures Thank you very much Quote Link to comment Share on other sites More sharing options...
zippy Posted May 4, 2022 Report Share Posted May 4, 2022 Tap harder. May need to use a metal headed hammer to provide a decent shock to dislodge the crankshaft. not a HARD hit, but a good tap. Quote Link to comment Share on other sites More sharing options...
richt Posted May 4, 2022 Report Share Posted May 4, 2022 You just need to start it moving. Try a hammer but usually I use a "Copper Knocker" as they don't bounce back instead they provide a dead hit meaning all the force is used. It's a bit of strange science but it works well. Quote Link to comment Share on other sites More sharing options...
garydwall Posted May 5, 2022 Author Report Share Posted May 5, 2022 Thank you very much for the replies.... Sorry just one other thing to ask. What is the best method to remove the bearings then... thanks Gary Quote Link to comment Share on other sites More sharing options...
mcman56 Posted May 5, 2022 Report Share Posted May 5, 2022 If the bearing is stuck in the case, use something like a heat gun on the case. (Aluminium expands more than steel when hot.) There is a tool made for pulling the case off. https://www.rockymountainatvmc.com/parts/tusk-crankcase-splitter-p 1 Quote Link to comment Share on other sites More sharing options...
