Txt 250 crank shaft removal flywheel side
garydwall
Hello can someone please advise me.
I have my engine split to replace the crankshaft bearings.
The crankshaft is stuck in the flywheel side of the casing.
I've tried a tap with a rubber hammer but no joy.
Any suggestions greatly appreciated.  See pictures
Thank you very much20220504_202120.thumb.jpg.feb4e937b4e55e2730434acf805a496e.jpg20220504_202131.thumb.jpg.010787fa4142f0b2d673a9418f1009dd.jpg
You just need to start it moving.   Try a hammer but usually I use a "Copper Knocker" as they don't bounce back instead they provide a dead hit meaning all the force is used. It's a bit of strange science but it works well.
