Bike_Breaker Posted May 16, 2022 Report Share Posted May 16, 2022 I am a longtime lurker, but never had cause to make a post (or make an account) as I’ve always been able to find the information I needed already posted. However, I can’t seem to find anything on this issue. I have a ’21 250 TRS RR E-Start. The changing system on the battery for my E-Start isn’t working. I can re-charge the battery and the e-start will work for awhile but ultimately the battery dies again and wont turn over. I hit the e-button on a tree and had to replace it, but it worked fine when replaced. Can anyone give me some targeted suggestions about where to look. I am hoping it’s just something in the wiring. Any suggestions are appreciated! Quote Link to comment Share on other sites More sharing options...
arnoux Posted May 16, 2022 Report Share Posted May 16, 2022 Can I ask how are you re-charging the battery? Are you using a Lithium battery specific Charger, or charging from just running the bike. And if using a charger how are you connecting it, as there is a relay within the battery "box", so you have to make the connection on the battery side of the relay, not on the bike side. Quote Link to comment Share on other sites More sharing options...
Bike_Breaker Posted May 17, 2022 Author Report Share Posted May 17, 2022 (edited) I'm using a lithium charger to charge the bike. I run the bike for hours and it wont charge the battery at all. To charge the battery, I open up the battery housing and connect it to the terminals inside. Not exactly a quick task, since you got to take the headlight housing and everything off. I am surprised how long the battery will start the bike before it runs down. I'm pretty certain the alternator system isn't working. I don't think the battery is discharging or anything like that. I did pull the E-Start wiring diagram from TRS. I'm attaching it for anyone who might want to reference it in the future. I did not find anything amiss in the wiring when I looked it over last night. I'm going to do a voltage test on the alternator tonight. 21 TRS E Start Wiring.pdf Edited May 17, 2022 by Bike_Breaker Quote Link to comment Share on other sites More sharing options...
PJCplas Posted March 18, 2023 Report Share Posted March 18, 2023 Any joy with what it was I’m having same problem had brand new battery fitted and it won’t start at all started onve then acts like battery is dead an won’t charge from the bike Quote Link to comment Share on other sites More sharing options...
F5Dave Posted March 21, 2023 Report Share Posted March 21, 2023 (edited) A multi meter on the terminals should increase when the engine is running. DC voltage should go up to perhaps 14.5v at mid revs. ( haven't tried a TRS but general principle is the same). If it isn't you have a problem. You can then unplug the alternator and test AC voltage I'd be totally guessing here, perhaps 30 to 50 volts at mid revs. Clearly if its bugger all, then you problem is there. If its healthy, you problem is upstream. Which would throw immediate suspicion on the battery itself, but could be wiring or rectifier regulator. Edited March 21, 2023 by F5Dave 1 Quote Link to comment Share on other sites More sharing options...
bigfoot Posted March 19, 2024 Report Share Posted March 19, 2024 I have the same problem. It was running in the evening and flat the next morning. I understand there's a regularor/rectifier that likely knackered. I read a technical bulletin showing a simple test between pins 2 & 3 and 4 & 5. Pins 1 & 6 are the AC. I've not yet tried it though. Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted March 19, 2024 Report Share Posted March 19, 2024 There is the KISS principle. Quote Link to comment Share on other sites More sharing options...
lemur Posted March 19, 2024 Report Share Posted March 19, 2024 31 minutes ago, bigfoot said: I have the same problem. It was running in the evening and flat the next morning. .... Make sure it's not just your headlight staying on after you ride it. Quote Link to comment Share on other sites More sharing options...
Pastmyprime Posted June 9, 2024 Report Share Posted June 9, 2024 Mr. Bigfoot, Can you post or send that technical bulletin that shows the simple test for the rectifier/regulator? I sold my 2022 TRS to a friend recently and 6 riding hours after he bought the bike from me, his e-start has stopped working. He has replaced the button, but that didn't solve the problem. The bike has roughly 45 hours on it total, so it's hard to think that a component has failed, but still worth checking. Thanks Quote Link to comment Share on other sites More sharing options...
lemur Posted June 9, 2024 Report Share Posted June 9, 2024 All of my electric start problems repeatedly turn out to be related to the sprag bearing spring, I have both a 2021 and a 2023, replaced the battery on the 2021 and likely did not need to, the 2021 is on its second rebuilt sprag bearing and my 2023 sprag has failed in less than 37 hours of operation and I have been using the kickstart most of the time. That light weight sprag bearing spring is going to be a huge problem if we can't buy them cheap and 6 at a time. Quote Link to comment Share on other sites More sharing options...
nhuskys Posted June 9, 2024 Report Share Posted June 9, 2024 This is why other trials brands are not jumping on the "add on" E start wagon. KTM went through this with E start on Enduro bikes. The add on starters were problematic, and they fixed this by designing engines with E start from the drawing board. Quote Link to comment Share on other sites More sharing options...
lemur Posted June 9, 2024 Report Share Posted June 9, 2024 5 minutes ago, nhuskys said: This is why other trials brands are not jumping on the "add on" E start wagon. KTM went through this with E start on Enduro bikes. The add on starters were problematic, and they fixed this by designing engines with E start from the drawing board. I heard KTM uses the same sprag bearing setup. I knew the sprag was going to be a high maintenance item from the start but this is over the top, when you get a new bike from the factory and it already sounds like a bag full of hammers that's a big problem. Quote Link to comment Share on other sites More sharing options...
