helwart Posted June 2, 2022 Report Share Posted June 2, 2022 Halo, I have a problem with clutch, when I stop a motobike and engine is still working, motobike is not riding there is no chance to put N neutral gear. I have to turn it off then neutral gear is geting without no any resistant. Next problem is that when I push a clutch lever (handlebar) and shift a gear the bike is riding very slow without pushing back the clutch lever. I`ll be very glad to get any sugestions from You. Quote Link to comment Share on other sites More sharing options...
turbofurball Posted June 3, 2022 Report Share Posted June 3, 2022 Hi Helwart, there is a possibility that both these problems are caused by a simple problem - if the clutch cable does not have enough tension when pulled in then it will cause both these things. If the cable is in good condition (not stretched or cutting through the outer tube) and properly adjusted and you still have the problem then it may be time to inspect the clutch itself. On my 349 I have trouble getting neutral when the engine is hot, but I just live with that problem! Quote Link to comment Share on other sites More sharing options...
