Easy Start
beta_basher
what is it? if its ether, (diesel engine starting fluid) it works great, but tends to wash the oil out of filter and off the parts inside the engine. Have seen bad effects and seized pistons.
I use WD40 as starting aid if the weather is good, only small amounts of ether if very cold.
k
Its not the engine that gets addicted, its the person squirting it in because it's easier/cheaper to do that than fix the real problem that makes the engine difficult to start.
Some diesel engines do need it, the manufacturer even build a way of using it into the vehicle but trials bikes do not need it.
Beware a large application can cause serious damage to engines, especially 2 strokes. I would never use it unless in very extreme minus temeratures which we don't tend to get in the UK.
Mark T
Edited by Timp
