1970 Montesa Cota 247 grinding noise
Niro
  • 1 month later...
Sounds pretty normal to me but I may be missing exactly what you are hearing. Might have a bit of piston rattle but not unusual imo. The cylinder fins can make any noise sound louder some times. Also try pulling the clutch in at idle to see if it changes. You might be hearing some primary gear noise..
