stogga Posted June 11, 2022 Report Share Posted June 11, 2022 Hi all. My son has damaged his radiator today and after looking at replacements on web they all seem to have an additional port on the top of them . . Can anyone shed any info on what this port is for as the 70 cc rookie does not seem to have it Quote Link to comment Share on other sites More sharing options...
stogga Posted June 12, 2022 Author Report Share Posted June 12, 2022 Hi It seems after some research that the older txt radiators had the thermostats inline and not in the radiator itself. Does anyone know if these older rads are available or could the port be blocked out and the new type used. Regards Neil Quote Link to comment Share on other sites More sharing options...
rcgods Posted June 12, 2022 Report Share Posted June 12, 2022 You might be better off taking it / sending it to a radiator specialist to be re-cored. Nothing special about them, they would sweat the tanks off the top and bottom and replace the core (assuming that is the damage.) They might even be able to repair. A quick google found this lot https://www.radiator-repairs.co.uk/radiator-repair/motorcycle-radiator-repair/ not a recommendation Quote Link to comment Share on other sites More sharing options...
stogga Posted June 13, 2022 Author Report Share Posted June 13, 2022 Thanks for your message I'll try that Quote Link to comment Share on other sites More sharing options...
