Jimmy124 Posted July 15, 2022 Report Share Posted July 15, 2022 Hello. my beta 270 rev 3 2005 wont start. new ignition coil and start plug. new piston and cylinder. I have spark on the plug. It wont start, why? Can someone help me 🙏 can it be the stator? Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted July 15, 2022 Report Share Posted July 15, 2022 (edited) If Mikuni, might have flooded. Check Spark Plug, If wet might have flooded. Edit: This happened often to me before i learnt what to do Edited July 15, 2022 by carl ekblom 1 Quote Link to comment Share on other sites More sharing options...
trialman Posted July 16, 2022 Report Share Posted July 16, 2022 check the woodruff key,trials bikes are a bit prone to shearing them..you get a spark but its out of phase. Quote Link to comment Share on other sites More sharing options...
Jimmy124 Posted July 16, 2022 Author Report Share Posted July 16, 2022 Thanks trailman, I Will check the woodruff. But the bike have compression and had even tried startspray. It wont start. but i Will check that out! Quote Link to comment Share on other sites More sharing options...
dan williams Posted July 17, 2022 Report Share Posted July 17, 2022 Trialman is most likely correct. It's common for bikes to shear the woodruff key if the engine has a sudden stop. Especially if the flywheel nut isn't properly tightened as the flywheel is an interference fit to the crankshaft. The woodruff key is just for alignment. It is possible to have a bad stator as well and still have spark. What usually goes out of these older stators is the trigger coil that tells the CDI where to fire. If the trigger signal is weak the CDI could be firing in the wrong location so you have spark but in the wrong part of the cycle. Quote Link to comment Share on other sites More sharing options...
Jimmy124 Posted July 17, 2022 Author Report Share Posted July 17, 2022 4 hours ago, dan williams said: Trialman is most likely correct. It's common for bikes to shear the woodruff key if the engine has a sudden stop. Especially if the flywheel nut isn't properly tightened as the flywheel is an interference fit to the crankshaft. The woodruff key is just for alignment. It is possible to have a bad stator as well and still have spark. What usually goes out of these older stators is the trigger coil that tells the CDI where to fire. If the trigger signal is weak the CDI could be firing in the wrong location so you have spark but in the wrong part of the cycle. thanks, I need all help I can got. do you know how many ”Ohm ” the stator is? If i can use a multimeter. And where I can buy a stator. thanks! Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 17, 2022 Report Share Posted July 17, 2022 You need to check all grounds. Did you paint anything? It is possible to have a spark and no spark with the plug in the head. Quote Link to comment Share on other sites More sharing options...
timdog Posted July 19, 2022 Report Share Posted July 19, 2022 If it comes down to the stator, the ref 3 was noted for stator failing, then West country windings do an exchange for reconditioned one. How strong is your spark, is petrol definitely get to the carb, i.e no blockage in tank? Strong blue spark could be timing out due to Woodford key/flywheel loose Quote Link to comment Share on other sites More sharing options...
timdog Posted July 19, 2022 Report Share Posted July 19, 2022 Was it running then packed up, or won't start after a rebuild Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted July 20, 2022 Report Share Posted July 20, 2022 Good question👍 Quote Link to comment Share on other sites More sharing options...
ascended_master Posted July 27, 2022 Report Share Posted July 27, 2022 (edited) The plug can test good with a fat spark but break down internally under further load and thermal variance. Just has a brand new NGK do this after three hours. Finally ran after many kicks but spluttered to a stop after a minute. Sounded as if the timing was badly retarded when it did run briefly & I was convinced that was the problem after I eliminated the usual carb issues on a brand new bike. Another new plug fixed it at the dealer! Edited July 27, 2022 by ascended_master Quote Link to comment Share on other sites More sharing options...
jamie1234 Posted September 7, 2022 Report Share Posted September 7, 2022 On 7/15/2022 at 7:12 PM, Jimmy124 said: Hello. my beta 270 rev 3 2005 wont start. new ignition coil and start plug. new piston and cylinder. I have spark on the plug. It wont start, why? Can someone help me 🙏 can it be the stator? Did you find the cause of this?mines doing the same and I suspect the mikuni carb. Quote Link to comment Share on other sites More sharing options...
