Mont 4RT headlight removal
martinh
Hi - I am looking to remove the headlight off my ‘21 Repsol 4RT and replace with a number board. It’s been suggested to me that the terminal block under the tank that takes the wiring from the headlight can just be unplugged, however this block has more than just the headlight wires going in to it. Can anyone help guide me in the right direction, please? Thanks.
Edited by martinh
If its just about getting a number board and your okay with the wires still being there I would just unplug the bulb, pull the headlight, unbolt the tank and feed the wire back under the tank and zip tie it out of the way then put the tank back on and maybe even cover up the plug end and then put the number board on the forks.
If you want to pull the wires all the way out I haven't gone that far into mine and don't have the time to fully investigate, sorry and good luck.
Edited by jonnyc21
