mudplugger124 Posted August 10, 2022 Report Share Posted August 10, 2022 I have a 2022 125cc GP. The last trial I rode at the weekend. The clutch got very heavy to pull in. And then it would get light again, the clutch still worked OK either way. What would cause this or is it normal. Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted August 11, 2022 Report Share Posted August 11, 2022 I don´t think normal and it happened in a short period last weekend. I would investigate the cause of friction and find a remedy. Quote Link to comment Share on other sites More sharing options...
jackman290 Posted August 11, 2022 Report Share Posted August 11, 2022 That has so be frustrating on a brand new bike. Definitely not normal. Maybe the clutch drive/friction discs are catching on the clutch basket edges? Have you tried changing your transmission oil? Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 11, 2022 Report Share Posted August 11, 2022 Likely you do not have enough free play at the lever. Quote Link to comment Share on other sites More sharing options...
mudplugger124 Posted August 11, 2022 Author Report Share Posted August 11, 2022 On 8/11/2022 at 1:25 PM, jackman290 said: That has so be frustrating on a brand new bike. Definitely not normal. Maybe the clutch drive/friction discs are catching on the clutch basket edges? Have you tried changing your transmission oil? Expand The transmission oil is changed every couple of hours. It is frustrating it was working fine until last week. Quote Link to comment Share on other sites More sharing options...
d2w Posted August 12, 2022 Report Share Posted August 12, 2022 Check the basics first; How tight is the bolt which snugs the lever to the housing at the pivot point? Is something restricting that movement? Check the fluid level in the master cylinder. Quote Link to comment Share on other sites More sharing options...
mudplugger124 Posted August 12, 2022 Author Report Share Posted August 12, 2022 Thanks for all the help. I found it, the edge of the O ring had broke off and got stuck in behind one of the paddles. I will give it a good try tomorrow. Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted August 13, 2022 Report Share Posted August 13, 2022 (edited) Mission accomplished👍😁 Edited August 13, 2022 by carl ekblom Quote Link to comment Share on other sites More sharing options...
