Clutch lever feel
mudplugger124
5 hours ago, jackman290 said:
That has so be frustrating on a brand new bike. Definitely not normal. Maybe the clutch drive/friction discs are catching on the clutch basket edges? Have you tried changing your transmission oil?
The transmission oil is changed every couple of hours. It is frustrating it was working fine until last week.
Check the basics first; How tight is the bolt which snugs the lever to the housing at the pivot point? Is something restricting that movement? Check the fluid level in the master cylinder.
